Stuck CD round two
shiney
Stuck CD round two
Unread post by shiney »
Ok. It looks as if the carpet and the cradle are bolted into the boot below the hatch door.
Looks as though I am going to have to remove the plastic lining of the boot. Am I right in thinking all I have to do is remove the rubber seal and it will come free?
If so, how much of a bitch is it to get back on? ie should I leave it to the weekend.
I am rather hamfisted at these things.
Chrispy
Unread post by Chrispy »
Sheesh, they put this thing in well didn't they! Well, if the boot rubber seal is anything like the ones round the rear doors then you'll be fine. I ripped those off to fit my changer and they went back on fine. I agree though, taking trim off is the worst thing in the world. Awful job.....
shiney
Finally removed it, bloody fiddly but didn't need to take anything out.
Partly stripped it but cassette refuses to come out, goes through the ejection motions but stays stuck nowhere to free it from and I can't see anyhing jamming it.
Looks an expensive trip to a dealer[:(!]
PowerLee
Unread post by PowerLee »
Hi
Try If you can, To get at the bottom of the CD cassette, Thats where the CD changer thingy goes in the little slot on the cassette.
shiney
The plastic strip did the trick and a lever was disengaged.
Thanks for the tips guys its fixed now!
