Another month and another lot of xantia problems (95 2.0i 8v). Noticed the other day a disturbing watery sound when revving the engine - like a bathtub of water being spun up. I remembered this on my old AX - it was a lack of coolant, somehow causing this noise. And again this is the case - the radiator seems to have corroded and developed leaks all along the bottom. Is this typical of a car seven years old? Seems a bit premature to me. But why hadn't the temperature gauge shot up? It didn't give any abnormal readings. I've also noticed very recently the oil level's dropped from max to min - less than two months ago it had a huge 72,000 mile service and certainly left with a full load of oil. Is the sudden drop somehow connected to a lack of coolant (my AX had actually ran out of oil when I discovered the coolant was low), and recently, a very small but noticable lack of torque? I've been using optimax for the last few hundred miles, I WAS very impressed with the increased torque at lower speeds/higher gears, but lately that's less so, the car seems to be finding everything a bit more of a struggle.
Also, it idles rather roughly sometimes, I think more when cold. A couple of times recently, it's not started at all - engine turned over, idled poorly, then died, once causing me to leave it overnight in a carpark only to find it started immediately next day! That's not happened for a few weeks now, but it does sometimes behave as if, when idling, it's about to conk out, but just comes round again. Othertimes it idles very smoothly. What could this be?
Oh, additionally - does radweld actually work? If so, how?
I'd really like to have this thing last out a journey from yorkshire to london and back this weekend - would prefer not to travel in my mates little nova
dan.
Edited by - D.Slatford on 09 Oct 2002 21:44:44
