ZX steering/suspension problem
Dave1
- x 3
For some time I have experienced an irritating knock each time I travel over a bump whilst making a right turn. The knock is definitely on the front nearside. It has been suggested it may be the rubber mounting at the top of the strut, or possible play in swivel hub.(I have had new arm and all bushes fitted plus drop links)The hub joint is also new but there is a little up and down play if you place a lever there, about 2mm. Is that normal? Has anyone any experience of this and what was the cause?
