Hi!
Guys, does anyone here know a way to remove the instrument cluster of the C5?
Unfortunately, i don't know if this can be done without removing the whole instrument panel.
Thank you very much[:)]
C5 instrument cluster
- x 1044
I take it you mean removing the cluster with the speedo & rev counter ? if you look at the bottom of the panel you will see two small dots,carefully insert a small plastic lever or similar under each one of these & CAREFULLY lever out the clocks,there are no screws of bolts holding it in,to re fit just push it back in.
406 V6
Rostami
