Xantia calipers
Joe Pineapples
Xantia calipers
Hi guys, I'm about to change the front calipers on my '97 Xantia, and I was wondering if there were any differences in the procedure from that of any other car, specifically regarding bleeding them once fitted? Any help or tips would be greatly appreciated!
JohnD
- x 72
- x 94
ghostrider
Bleeding hydraulic Cit brakes is easy, none of that "up, down , hold it up, down, up down .......oh S**** out of brake fluid " [:D] [:D] stuff, start engine place bleed tube on bleed nipple, slacken nipple one turn or so, GENTLY on the brake pedal, once you have nice green fluid coming through tighten nipple remove bleed tube stand hard on brakes to check for leaks, top up LHM, dispose of stuff you bled off. The only thing with the Xantia's calipers is that the nipple is none to accessible, but at least they don't seem to corrode quite as badly as BX ones
Pete
________
ULTIMATE FIGHTERS
Pete
________
ULTIMATE FIGHTERS
Joe Pineapples
Hi Malcolm,
One of the calipers had siezed and needed replaced, so I took the oportunity and ordered new calipers, discs and pads. Should make it sound for another 100,000m at least.
Hi Pete,
I foolishly looked in the haynes manual to guide me in bleeding the brakes, but they'd have you bouncing the car up and down like a pogo-stick!
Hi Pete,
Joe Pineapples
- x 94
