XM Yo Yo
zzf00l
XM Yo Yo
hi guys we've got a 1994-Mreg citroen xm 2.5td coming in and the rear suspension has a mind of its own!customer says that the rear suspension rises and falls whenever it likes,for example he will pull up at traffic lights the rear suspension goes right up then down very quickly,he says there is a noise from the front then itdoes it. it even does it for a while when he takes keys out! it started of occasionally but is getting very frequent now any ideas any body? we changed the accumulator sphere thinking it was down to pressure loss but this made no difference help! i meant to add that all corner spheres seem ok(soft)
JohnT
It do not have the answer but this site is the best for info on citroen hydra systems, hope it helps.
http://www.tramontana.co.hu/citroen/
- x 1238
AndersDK
Oscar Too
WD40 the height correctors then grease them up liberally. I don't know how easy it is to access the height control linkages on an XM but they will benefit from a good greasing. My BX started jumping randomly but was sorted out with liberal applications of grease.
Don't forget the customer's driving style may make the car jump, or make jumping worse - if he rams on the brakes at the last second at the lights for instance, the front will sink and back come up and will then correct.
zzf00l
