got a feeling that i got water mixing with the oil but not oil in water, if you know what i mean
what cud it be?
water in oil
pug_owner2002
- x 3
Richard Green
- x 8428
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by b21playa</i>
will head repair sealant work?
Nooooooooooooooooooooooooooooooooooo!!!
- x 8428
What are the symptoms you are seeing and what form is the water taking. It's not just a bit of Mayonnaise is it? (white emulisified mess in the cooler parts of the engine) Never known it in an XUD but some petrol XUs are terrible for Mayonnaise, usually when they're used for short trips and never get hot enough to boil off any condensation in the oil. If you do just short trips or your thermostat is stuck open leading to overcooling than that can cause it. I'm looking for other causes apart from the HG. Is there any other signs of the HG failing like excessive coolant loss, pressurisation of the coolant from cold and white smoke out of the exhaust. A search around this forum will help you find all the classic HG failure warning signs..
b21playa
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by citrojim</i>
well was loosing cooleant but that is because the radiaotr has gone
will repalce and then see
