OK… Job No 20 of 550 and growing !!! [;)]
Ignition ping.
My Xantia 2.0/16v XU10J4 has a slight ignition timing ping in 5th up hills or hard acceleration in 3rd/4th/5th gears. It’s only slight but if it’s fixable I’d like to track it down.
Anyone know the most likely/common cause in 2.0/16v. Should I be thinking of throttle potientiometer and/or knock sensor? Or should my question be `how long is a piece of string!’
Cheers
Steve
FIXED - 2.0/16v Xantia Ignition ping
it doesnt have a knock sensor but it does have a cam sensor which is about the same thing to check it, expose the connections "do not remove the multi plug" then using a volt/multimeter test terminals 2 and 3 voltage should read 4 volts fluctuating, if that's ok then try a better petrol station or use Optimax ( which I think is well over priced ) or use a fuel booster additive.
edited because I forgot one of the <b>"</b> out.
STP is the most used try some then go to the sensor, sensor is on the right hand side rear of the cylinder head.
http://images.google.co.uk/imgres?imgur ... en%26lr%3D
Update:
I’ve noticed engine only seems to ping when engine is warm, 80/90oC or above. I’ve tried to re-create conditions with cold engine and so far… No ping.
Also stumped up the extra 3p a litre for a tank of 97ron. Initial test made no difference but I’ll see how things go after a week before trying octane fuel additive.
Cheers
Steve
Cheers
Steve
OK – Fixed at long last… ACAV electro-valve fitted.
See http://www.frenchcarforum.co.uk/forum/v ... highlight= for details.
http://www.frenchcarforum.co.uk/forum/v ... highlight= for associated symptoms
Thanks one and all for help.
Cheers
Steve
Cheers
Steve
95 Xantia 20/16v 155 bhp VSX 210k
97 Saxo 1.1 SX 100k
03 S-Type Jag (sorry!)
``Only standing on the shoulders of giants - The more I know, the less I understand?? Ignorance is bliss! ''
97 Saxo 1.1 SX 100k
