I asked for help a while ago because my rad fans were not working when I switched my aircon on although it tuned out they worked when the engine got hot. I just put it in to have the aircon regassed (£60 at a refidgeration place not garage) and within ten seconds both fans came on, so it was just that it was low on gas. I haven't had it done for three or four years so I guess it was ready. I thought I would mention this in case it helped someone else.
Robbie.
Update on rad fans not working
ghostrider
Hey a Xantia air con problem with a simple solution [:D] [:D] [:D], enjoy it anything has to be better than my nightmare, question is why if you have something that doesn't work but isn't strictly necessary do you persue it to the bitter end to fix it? [:D] after all I've never had aircon before and never worried about it, but now I've got it I just won't be satisfied until it works again
Pete
________
Home Made Vaporizer
Pete
________
Home Made Vaporizer
- x 94
ghostrider
You could be right there Citronut, the large suspension pipes for the VSX running across there are certainly rotting nicely [:D] [:D] [:D] [:D]
Pete
________
FERRARI 308 GTB HISTORY
Pete
________
- x 94
