Coolant Mayo
dillosk8ter
Coolant Mayo
Unread post by dillosk8ter »
When I was playin round with my BX14 today I found creamy sludge on the underside of the radiator cap, is this anything to worry about? Did immediatly check the oil filler cap and all seemed fine there..thinking of popping it to garage for compression test. Thanks in advance. Owen.
Stinkwheel
Unread post by Stinkwheel »
I think I remember that these engines suffer from mayo in the cap if short journeys are done so that it never really burns off the condensation from cold starts.
AndersDK
Unread post by AndersDK »
Check your thermostat. Could be the oil from the wax cylinder in thermostat.
From cold with engine idle :
With your hand keep a feeling of the engine temperature on the large tophose to the radiator - closest to the radiator.
The water should keep the tophose cool for lengthy time - then abruptly increase in temperature when thermostat correctly opens at engine work temperature.
A few minutes later the cooling fan should cut-in at 1.st stage.
If the tophose temp raises sloooowly all the time - almost forever - the thermostat is defective (stuck open).
