Washers??
dmcclymont
Washers??
Unread post by dmcclymont »
Hmm, washers work under protest, poor flow front and rear and I suspect the pump (or should I suspect a block?? are the pumps ultra reliable?)
Do I need to take a wing off to get to the tank? Looks like I do?
Any advice anyone - thanks.
oilyspanner
Unread post by oilyspanner »
Try running a solution of bio washing powder through it first, it can dissolve the stubborn understains that cause poor screen washing performance[:D]
Stewart
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dmcclymont</i>
Are we talking Xantia here? If so - jack it up securely and remove front o/s wheel. You may also need to remove some wheel arch liner.
lighteninguk
Unread post by lighteninguk »
i would start simple, first try poking the nozzles with a needle... then, if that doesnt help, you can easily clean the pipes which attatch to the bonnet for the front by disconnecting it and blasting a hose down one end. another thing is whilst poking the nozzles with a needle (or other fine implement) get an assistant to turn on the washers, (whilst dodging the whipers and the squirting water and being laughed at by your assitant) try wiggling the needle in the nozzles openings it seems to clear the nozzles up super
