xantia clutch cable jobbie.
bonnie the botch
hello all, hope you can help, have a 1.9td xantia 96 n , the clutch cable came off at the pedal assembly end as a result of the spring clip failure and breakage the plastic jobbie that goes with this is missing. the cable is of the mech flavourand apears to be un-broken, but we cant see how the clip and plastic bit goes back on ,Q1, is there a specific tool for this task, Q 2 does the whole pedal assembly have to come out to do the job. any advice welcome thanks in advance
AndersDK
bonnie the botch
PowerLee
