Xantia Clutch Cable
Andy
Xantia Clutch Cable
Unread post by Andy »
Hi
I am replacing the clutch cable on My xantia 1.9 TD, because the plastic clip keeps on braking off the pedal.
I am sure that the old cable wasnt routed correctly I have looked in the manual and all it says is fit the new cable the same route as the old one, making sure that it is fastened to the bulkhead,.
Well my old cable wasnt fastened to the bulkhead and it was very stiff to pull through the sleeving.
I have checked the cable and it is fine when off the car.
Does anyone know the correct route that the cable should go from the pedal to the clutch any advice very much appreciated
Andy
Andy
well I replaced the cable along with the plastic clip and its snapped again,
Looks like it needs a new clutch again, only had the last one fitted last December. Has anyone else had any probs with this bloody plastic clip.
Andy
Andy
AAAAAAAAAGGHHHHH £300 for a new clutch and its snapped again Help Please before I dump the car in the river
