Hi Folks,
I have a Renault 5 1995 model. It's idling very fast and my workshop manual covers every carb' under the sun but this one! There are various electronic bits and bobs attached and what looks like a fuel enrichment gizmo of some sort mounted above the carb which is clearly electronically controlled. Is the a physical adjustment to make here, a loose connestion or a new bit required? I can see a fair amount of fuel being squirted in above the butterfly.
Also The clutch is engaging very early in its travel. Would this imply a problem with the adjusting 'quadrant' a stretched cable maybe.What do you think?
All the best Mike
Renault 5 Idle Speed
wilkobob
Richard Green
- x 94
j_roc
Dont you mean the "CFI" unit - central fuel injection. It looks like a carburettor, but has a single injector in the center of it, inplace of four single injectors built into the intlet manifold. Whats the mileage of the car? Adjustment of the CFI unit will require the emmisions to be set up afterwards. Hope this helps.
