Please can someone confirm the procedure for reprogramming a Mk2 Xantia key. The immobiliser works fine as it's only had a new board fitted. I've looked through previous posts and I can't seem to get it to work?
Regards
Xantia Mk 2 Reprogramming Help
howiedean
- x 1044
citroenzx
http://www.andyspares.com/discussionfor ... C_ID=14281 any help?
when i spoke to some guy about a new plip for my ZX he told me that if i got the number of the receiver and gave it to citroen they would be able to get me a new one for about £30
howiedean
JohnT
citroenzx
- x 1044
you can only order by number on certain IR type plips,the mk2 xantia uses an RF type which can only be coded (as far as im aware) with the dealers diagnostic computer,you should have a grey plastic credit card sized card with the the transponder code on it,it should be 4 digits long & can be a combination of letters & numbers,the code is under a small scratch off panel.you need this code to program keys & plips,if you dont have the code citroen will charge you aroun £15 to get it.
howiedean
howiedean
