whinning noise, help!
Andrew1967
Unread post by Andrew1967 »
There is a whining noise on my Xantia 1.8i N reg, now it goes up in pitch as a speed up but doesn't change with the revs , it is purely speed no how hard I press the accelerator!
Any ideas????
Andrew
Dave Burns
Unread post by Dave Burns »
Most likely causes are wheel bearing's, righthand driveshaft intermediate bearing or differential/gearbox bearing's.
A wheel bearing will often make more of a racket when turning in one direction than the other.
Dave
Andrew1967
Thanks Dave, will listen out to see if it makes more noise when turning.
Andrew
marco1
Unread post by marco1 »
hi im haveing fun my self at present done both wheel bearings still whinning its going to citroen tomorrow to check it out ..ill keep you informed.
Andrew1967
Thanks Marco, please do........ Was it difficult to change them, am a novice but would give it a shot if it was not to expensive and difficult to change them!
Andrew
marco1
hi,well went to citroen garage went out for a testdrive....with all his experience of citroen,dont know what it is...bloody great.still didnt charge me, if with hearing devise it would have been £40,but he has never had a problem like this,its not gearbox,driveshaft,or wheelbearings as ive done them ,he also said they,ve not done any!he was surprised i done them..anyway he said it could be tyres but there new and i didnt have noise for 3 weeks after i fitted them so im not convinced ..plus i swoped back to front diff tyres no change its got me.if you go route of bearings you,ve got to take hub off need a ball joint splitter and big socket and 3/4 drive and a big bar they are tight!not a hard job about an hour buy bearing got to go to a garage with a press its the only way but wont charge much only takes 20 mins about..so there you go ive just got to run it and see what happens.
alan s
RIP 2010
x 6
Unread post by alan s »
I mentioned on another thread that I had a similar experience and it was tyres. In that instance it was on a CX but on a BX I had a situation where the tyres made a noise as though I had a flat on a certain type of road surface, about 400 metres long near where I live but a road I don't travel on often. Twice I stopped and inspected the tyres as they growled so loudly and I imagined I could feel a bit of sound transmission through the steering. When I changed tyres I also changed brands and never had the problem again.
The CX had an Asian brand of tyre that whined like a faulty bearing but the "flat tyre" syndrome was from a good quality Michelin. In both cases it was put down to tread pattern. It could easily be the tyres as it would take possibly 3 weeks of average driving in certain patterns to bed the tyre in enough for the problem to show. I wouldn't write the tyre off as the cause as I think it just could be.
Alan S
marco1
humm ive tryed that swaped back to front still got it ill try again ive never had this before, citroen dont know either!!
alan s
RIP 2010
x 6
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Marco,
The fact that you have swapped back to front without success is one of the reasons I suspect this is your problem; same tyres still on the car even if they are in different places - been there - done that<img src=icon_smile_big.gif border=0 align=middle>
The ideal siuation would be if you knew someone with a completely different brand & style of tyres and do a complete swap...say a set of Pirellis replacing Michelins. Out of curiosity, what brand & type of tyres do you have on the car? May be worth posting that in case others have the same sort & have a similar type of noise.
Alan S
marco1
na different tyres on back.thats why i dont think its tyres.ive had over a dozen cars ive never had a prob with tred/tyer noise.i cant imagine its a gearbox prob.i might try a cheap drive shaft from scraper.just to break down the prob..
