Hi All,
I'm toying with the idea of fitting power steering to 93(L)Trafic diesel camper, has anyone done this?
I'm looking for any clues as to what parts i might need?
other than a rack, pump, pully, does it also need a different column etc?
Was it a common fitment on this model?
Any help or info would be appreciated.
Thanks skes
Trafic (93) power steering?
skes
If anyone is interested, i managed to acquire a full power steering kit (£166 inc p&p) off a 96 model, everything fitted great all holes already there, the only problem i had, because it was off a facelift model the steering wheel end of the column was different, had to adapt the stalks etc.
A lot better for parking etc.
Parts i got were...Rack,Pump,Reservoir,Pipes,Steering Column (shorter),Crank Pully even drive belt and bolts.
