Petrol in diesel, only a small amount!
JohnT
Unread post by JohnT »
I have two gallons of diesel with petrol in it, diesel 70% petrol 30%, can I put the lot in to my Xantai diesel if topped up? Will it cause damage? Or bin it?
FrenchLeave
Unread post by FrenchLeave »
It seems to me that diesels have been run on far worse mixtures than that, just don't try putting it in a petrol engined car!
jeremy
Unread post by jeremy »
Value of contaminated fuel £8 - cost of repair £?
Approximate quantity 5 pints petrol - bit more than needed as a cleaner.
Do you like gambling?
Jeremy
j_roc
Unread post by j_roc »
If you love your Xantia you wont put the crap into the tank. "Somebody" put super unleaded into a 5 year old Vauxhall Astra 1.7 td (1995 model) for some unknown reason she "forgot" to tell me. The result - sitting on the outskirts of Camarthen wondering what the hell was wrong with this car? The end result was one fuc**d Astra. Even today I still remind her to put the correct fuel in. It is your car after all.
Homer
x 16
Unread post by Homer »
Well I hate to see waste so how about putting a few pints in at each fillup?
AndersDK
Unread post by AndersDK »
Must be a few pints pr brimmed tank then.
Used to clean my BX diesel foam air filter element in petrol. This was enough to have quite a few violent "pops" from the exhaust. But in this instance the petrol is getting in the wrong way.
Try do a bit more accurate calculation on the final dilution. You can not be wrong if you are within the mix for cold winter running.
JohnT
Thanks to all.....will use it as a cleaner to be on the safe side.
Mandrake
x 694
Unread post by Mandrake »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JohnT</i>
[:0][|)][?][xx(]
Why take the risk ?
Regards,
Simon
