Does the Xantia use OBDII ?
wotsupnow
Unread post by wotsupnow »
There's an article and likely a kit out next month.
http://www.elektor-electronics.co.uk/De ... x?tabid=46
Pete
jeremy
Unread post by jeremy »
You may find this site interesting - I seem to remember there is a list somewhere and that they are talking about self build jobs.
Not much use of a TD BX!
http://www.scantool.net/index.htm
jeremy
bernie
Unread post by bernie »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by wotsupnow</i>
Pete
I might have a go at that[:p][:p]
Kowalski
Unread post by Kowalski »
Somebody remind me to buy a copy of that magazine when it comes out....
Richard Gallagher
Unread post by Richard Gallagher »
To see whether your Xantia uses OBD take a look at the socket in the fuse box. If its like the plug shown in the link picture then it more than likely does.
As a rough guide, MK 1 models generally don't whereas MK 2 do.
406 V6
Unread post by 406 V6 »
Don't take the OBD-II plug for granted.
My mom's 406 (12/99) has it and the C5 too, but they are not compatible with OBD-II, the pins and protocols are propietary.[:(]
It works on Vauxhall, though [:)](Frontera 2.2DTI)
Kowalski
There are a number of different standards for OBD-II, non of them compatable with one another and using differing pin-outs on the same plug.
sdabel
Unread post by sdabel »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jeremy</i>
jeremy
Downloaded the software and it looks ok. Has anyone used the scanner on a Citroen?
regards
sean
406 V6
As i said, itdoesn't work. i have the ELM ISO chip/board and software, but it's useless on the C56and 406.
Kowalski
There is another place I found doing diagnostics stuff.
http://obddiagnostics.com/
They use a different chip.
And another site has another scan tool, but I don't know which chip it uses.
http://www.obdscan.net/
bernie
Pete
Anyone had a go?
