a tip on fixing abs
spliffy
a tip on fixing abs
my abs packed up on my xantia the light was on all the time when you first turned the ig on it flashed then stayed on this tells you that its a wheel sensor i then tested all four sensors using a multi meter i used the 2000 ohms scale and i got a reding of about 670 on three of the sensosors the last one i tested(it always is) did not give a reading so i replaced that one with one from scrap yard costing £10.cheap fix hey ! the way to test the sensor is to trace the wire back and unplug it then do the resistance test between both terminals i dont think it matters which ohms scale you use as long as you use the same one for them all but me and my mate scotty worked out that the one we used was more accurate
