Just looked at a 2001 C5 full service history including timing belt done less that 20k ago, car has 95 thousand on clock, drives fab looks the part the chap wants £2750 for it.
What have i missed for this price as all seemed to be great?
C5 2.0 sx what do u think?
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Petrols are always cheaper than diesels but this one looks too-good-to-be-true-cheap.
Has it been written off? Is it a ringer? Is it mechanically sound?
Ask lots of questions, if you're still happy after you've asked the questions part with cash, if not walk away it might not be the bargain it appears to be.
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
I don't like LPG - had an Astra that ran on the stuff at work - the £12 fillups were embarrasing - - it was rattly and needed 1000 more RPM to pull away when running on gas - then the engine blew up.
And because of the way it is taxed the government could make it as expensive as unleaded tomorrow so it's a bit of a gamble.
Have you worked out what mileage you would need to do to get the value of that LPG change? By my calculations you will not benefit unless you do in excess of 16,000 miles in your ownership. You will get less MPG from LPG, they reckon at least 10% less.
So you will need to do 18k before you get a payback on the conversion? Performance will be down quite noticeably.
Would the tank encroach in to your luggage space?
- New User
- My Cars: This is a dummy account added to fix some orphan posts.
Homer I would say the conversion done on your Astra was a poor one. My work's van run's on LPG and the tank hold's £20 when empty also it has done 80'000 miles of hard driving without any problem's on the LPG side. Was it a factory conversion or was it done after the car was bought? As for running and performance I put in £18-£20 @ 49.9 pence per litre and get 220-250 miles from a tank (van is fully laden all the time with ladder's on the roof)don't know what that is in mpg. The performance isn't good at all compared with petrol but mine is a single point gas injection. The newer conversions use multi point injection which is meant to be as good as running on petrol except the mpg. I would look into fitting an LPG conversion but think about the cost and how long it will take to get your money back and would you mind having some of the boot space taken up by the gas cylinder. All in all mine has been fine just DON'T GET A CHEAP CONVERSION you will regret it.
- New User
Forget to say I agree also on the fuel tax. I read an article last year in Practical Classics and basically it said that within 15 year's lpg could cost the same as petrol for exactly the same reason the price of diesel was hiked up (because more people are using it), the reason it's cheap is surely because it is a green fuel Mr Blair!!
