hdi fuel filter
meexi
hdi fuel filter
Unread post by meexi »
Does anyone know how to replace the fuel filter in my xantia?
all i can see is the filter holder with a plastic top that has a nut moulded in to it, Do you turn the nut clockwise or anti-clockwise and is the system self bleeding
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Put a socket on it and turn anti-clockwise. Use the hand primer to refill after the new filter is in.
martyhopkirk
Unread post by martyhopkirk »
Be prepared to shell out for a new filter housing too - they aint that durable and often fail to seal propperly again.
meexi
Do you take the two pipes off and only turn it a little bit or do you have to unscrew it?
x 1044
Unread post by wheeler »
its a quarter turn anticlockwise,take the pipes off first.change the seals,they should come with the filter.the system is self bleeding,there is no hand primer as there is an electric pump in the tank.
rossd
Unread post by rossd »
Unless you have the Siemens system, in which case you will have a hand pump!
