Xantia Rusty Strut Tops
x 8078
During my cambelt and waterpump change today I took the opportuniny to have a good look at my strut tops. They're rusty and although they're fair at the moment I will be looking to change them before the autumn.
Is it a case of replacing the whole strut? Shame as they are both in good nick otherwise, or are replacement mounting plates available?
What sort of a job is it to have the struts out?
Chrispy
Unread post by Chrispy »
I've asked this before....would be interesting to know the answer. I've doused the entire strut top in waxoil for now to preserve them. I wonder if the plate at the top is replaceable as a separate part.
jeremy
Unread post by jeremy »
I'm not quite sure what your problem is - if its the bodyshell itself that is rotting this is a welding job and I'm sure a specialist welder will do the job for a reasonable price - they used to do these things all the time on cortinas (Mk 1 and 2 but not 3 - and I'm sure there are others since that have needed this sort of repair. The result won't be beautiful but will be effective.
I can weld and have the kit but for this would see how much a professional would charge and probably let him do the job.
Jeremy
x 8078
Sorry Jeremy, I should have been a bit more descriptive. The bodyshell is 100% fine. The rust is on the plates at the top of the strut that sits under the bodyshell suspension turrets, the one with the four tapped holes in that receive the four bolts that secure it to the bodyshell. I've had a good poke around and it seems sound but flakes of rust came off.
jeremy
Unless the metal has thinned significantly in a stressed area I wouldn't think there is much to worry about.
jeremy
madasafish
Unread post by madasafish »
Spray with Dinitrol or Waxoyl: I do this with our 106 regularly at the bottom strut holding the spring..
ActivaV6uk
Unread post by ActivaV6uk »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jeremy</i>
jeremy
So you havent seen the XM/Xantia pictures with the strut out of the bonnet and a very badly bent bonnet?
The answere to your questions guys is yes its a part you can replace but it also has the black strut top as part of the item, its £76 ish from citroen and its model specific.
with the amount of force that goes through these when you turn the stearing wheel i would suggest that people keep an eye on it ot you will be replacing this and a bonnet at some point in the future if its goes and you missed it.
Andy
x 8078
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ActivaV6uk</i>
jeremy
I have Andy....
Scary.. For the cost of a bit of peace of mind that's going to be my next job!!!!
Thanks Andy...
ActivaV6uk
want me to find you the part numbers?
Andy
x 8078
Yes please Andy!
Mk1 1993 Xantia 1.9 SX TD RP6086...
Many thanks indeed..
ActivaV6uk
(First description and part numbers)
LEFT
SPHERE BRACKET
- POWER STEERING AND WITHOUT HYDRACTIVE SUSPENSION
(+ 5271 92 (01) UP TO 7244)
Part number - 5271E1
RIGHT
SPHERE BRACKET
+ 5271 92 (01) TO O 7244
Part number := 5271E4
(this is what the order looks like on PR.net)
00005271E1 HYD SUSPENSION SPHERE BRACKET 95.30 inc vat
00005271E4 HYD SUSPENSION SPHERE BRACKET 95.30 inc vat
Ask them if you can put it on a stock order and whether doing so will give you the 15% discount that you get from other citroen branches, if they say no, and you want to save 15% tell me and i will order them for you through my friendly citroen garage and ship them to you.
Best wishes, (and your welcome, I know how usefull it was when Jon use to do things like this for me)
Andy
x 8078
Andy,
You're a star! Fantastic. I'll go to my local Citroen dealer and report back.
Much appreciated...
richiesxantia
Unread post by richiesxantia »
How'd you go Jim?
I have the same problem with a '93 TD Xantia -
Where do I find the RP number?
I'm assuming I have the same struts as yours but want to be sure -
cheers,
Richie
x 94
Unread post by citronut »
you know that if your a CCC member you can get discount from cit dealer,also have you not looked at my pics on this topic if not look up strut top update, you should also remember there is 2600 psi going up into your strut top and more as it takes up road movment regards malcolm
x 8078
Hi Ritchie,
Funny, I thought I'd posted a reply on this. Maybe not in this thread though as there is a few threads on sililar topics.
Yes, basically, I nipped in to see my Local Citroen dealer and using Andy's most valuable information (Thanks Andy, really appreciated) I got my new tops for £88 each in two days. Genuine parts too.
The RP number is stencilled on the nearside bulkhead near the strut top along with the paint code. It's the 4 digit number.
Just need the time to do them now! I took your advice Malcolm, and got some new Drop Links too. I also got some new hydraulic seals just in case. All easily available from GSF.
I must say the pictures you posted Malcolm, in the other thread on this topic means I'll be doing them sooner rather than later. I printed one of the pictures in A4 size and have stuck it on my office wall to remind me! It's been quite a talking point at work...
