Wrong Radio Code
soupy_sam
Wrong Radio Code
Unread post by soupy_sam »
I have put the wrong radio code in Once in my Citroen radio and it has locked.
How do I unlock it please?
Richard Gallagher
Unread post by Richard Gallagher »
Wait...........It depends on how many times you have done it.
Each wrong code doubles the length of lockout.
soupy_sam
<font size="4">Only ONCE</font id="size4">
dnsey
x 19
Unread post by dnsey »
If you know a bit about electronics (or someone who does), you can reset it.
Disconnect the radio from the car, remove the covers and locate the memory backup capacitor. Discharge this with a low value resistor, and you will start again with a clean slate.
meexi
Unread post by meexi »
just press the band button and the lcd will flash then put in your code
JohnT
Unread post by JohnT »
Your radio will lock out for a short time only. There are several models and most have to be done differently, what model is yours? I will see if I can help you. If in doubt about the model, tell me where the on/off button is.
soupy_sam
on/off button is at the <b>bottom left hand side of panel</b>
soupy_sam
how long is lock out for and does the radio have to be <b>on</b> or <b>off</b> or <b>fuse out</b> or <b>disconected</b>?
JohnT
when u switch it on does it now show the word 'Code' ?
JohnT
If the code word is showing, try this sequence, if it dont work come back to me again.
Lets assume your radio code is 7234. Press the 1 station button until the 7 appears, then on to the second button and press until the 2 appears! when all four numbers are showing as the code press 6 and it should then be OK. If not do not do anyhting else, just switch off.
MW
Unread post by MW »
About that band button. If you've just got the word "Code" showing on the display, you need to press it for at least five seconds. Then it should reset.
soupy_sam
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by meexi</i>
<font size="4">Brilliant that works well</font id="size4">
