Hi, my '97 Xantia 1.9TD has recently developed yet another intermittent problem. About every third or fourth time I start the car the rev counter flicks momentarily up to about 500rpm a few times while I'm waiting for the glowplug light to go out. When this happens the car won't start the first time I turn the key. It cranks fine but doesn't fire. I've kept it cranking for as long as I dare (probably about 20 turns) but no joy. If I turn the key back to the off position then crank again it fires up immediately. The car normally starts on the first crank.
I don't really care whether the rev counter works properly or not but I do kind of like the car to start reliably. I can't imagine how a fault with the rev counter/sensor/wiring would affect starting - could it? Or could it be that the non-start fault is affecting the rev counter?
The car has the Bosch pump and the sort of 'half management' ECU which I believe can alter the injection timing a bit.
Xantia starting / rev couunter
splat
Well, the problem seems to have just gone away. I forgot to mention that another long standing problem of it running at cold start tickover all the time disappeared at the same time the above problem appeared, I am reassured to find that the high tickover has returned. Much better for crawling in traffic.
- x 1431
- x 94
it could be the imoberliser module on rear of fuel pump as they do go intermitent,or stop solanoid,if it is the imob they are about £170 squid but you can bypass it find a live feed that is only live all time ignition is is on like on glow plug timer box,conect it to shut off solanoid regards malcolm
