Low brake fluid warning on 406
acataldo
Unread post by acataldo »
I have recently bought a T Reg 406 GLX HDI 90. Whenever I operate the hand brake the LOW BRAKE FLUID warning comes up (never comes on any other time). I have check the levels and condition of the connection and level sensor and it all looks OK. Has anyone experience this issue before?
PowerLee
Unread post by PowerLee »
Hi
Replace the handbrake switch with the new moddified part from Peugeot & your problem will be solved.
zaki_406
Unread post by zaki_406 »
Is it on when you release or pull up?If after released,the low brake light came up,could be your brake fluid is really low.This is a sign of leak somewhere in the system.
If it lights up when u pulled it up,that's normal lah!(malaysian english must have lah at the back).
acataldo
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by PowerLee</i>
Hi
Cheers. I'll give that a try.
Deezel
Unread post by Deezel »
Hi I just bought a T reg 406 glx hdi 110 and mine does exactley the same thing when h/brake on, quick check on brake fluid to make sure it was full and now I dont worry about it [:D]all i need now is owners handbook Anyone got one they don't want ? cos I havent a clue what things are for yet , regards John [:D]
PS I have a peugeout 405 manuel a 505 manuel and a 505 diesel manuel covering diesels as fitted to 505 range, also 505 petrol manuel
PowerLee
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Deezel</i>
If you want to sort it, Fit the new modified handbrake switch & the fault will be fixed.
