Hi Guys,
I've been doing a few searches and can't seem to find anything that tells you how to hydraflush. What is the full procedure for this and where can I buy hydraflush? Do I bleed the brakes too with hydraflush and how long do I leave it in?
Any advice appreciated.
Cheers,
Chris.
Hydraflushing
Kowalski
Chrispy
I take it the hydraflush is like a kind of cleaning brake fluid then? I'm tempted to have a go at it as my system has a few quirks I'm sure it'll fix. Hopefully it'll be cheaper than LHM too as that's £5 odd for a litre! Just gotta grease my front struts too....they're a tad sticky judging by the way the front rises and falls in jerks.
Dave Bamber
Hydraflush cleans out the little nooks and crannies in the hydro system. Both available here:
http://www.gsfcarparts.com/
tonyb1
406 V6
Take the LHM reservoir out and clean it and it's filters. You can find a better and detailed explanation on a search on this subject.
The, you fill the system up with hydraclean, liek you would do with LHM.
Then, put the suspension fully up, and with someone inside the car to press the brakes (or a stick on between the pedal and the seat[;)]), open the brake bleed nipples until the color changes from green to orange (hydraclean's color).
Do this on every brake nipple.
Be carefull NEVER to stand under the car. It's never enough to warn on this subject.
Ride the car as usual for some 1.000 miles, and do the procedure again, but this time topen up with LHM. Done!
Fixed the mileage. thanks[;)]
- x 94
tomsheppard
fastandfurryous
- x 4
If you have hydraulic components to change anyway, is it recommended to do a hydraflush before or after changing them?
IE is the hydraflush lilely to transfer dirt from the system into your nice new component, or is it good to give a new component a clean out with hydraflush before filling with LHM?
Kowalski
If the system is dirty and you put in a new component, it will get dirty. If you do it before you change the component, any dirt you introduce while the system is open is a permanant fixture. The other way, your nice new component gets dirty then cleaned.
I suppose its a trade off, which is best will depend on how dirty the system is to begin with and how clean a job you can do of changing the components over.
user_3150
- New User
This is what you want Chris. I did mine recently and this was very helpfull (Cheer's Ander's).
http://citroenz.com/forum/viewtopic.php?t=27
mattpc
Good luck, I let westroen do mine as I couldn't be bothered in the end and it's made a real difference to both the braking and suspension systems. Despite the LHM not being too bad in colour, when the hydraflush came out it was black!! Now braking is less wierd/pulsey and the suspension is quicker to move into position.
