ABS sensor for BX GTi
mudinureye
Unread post by mudinureye »
Another question for you all.
Where would be the best place to start looking for an ABS sensor for a 19 GTi?
I am determined to bring this car back up to scratch!!
miked
x 6
Unread post by miked »
Under the wheel arch. (Sorry, couldn't resist it.)
GSF car parts list them under part numbers N64504 (front) and N64506 (rear)
VisaGTi16v
Unread post by VisaGTi16v »
Will be bolted into the actual hub with a lead going into so should be quite easy to spot with the wheel off
mudinureye
I worded that wrong, but, then again, I am Irish.
I know where it is, problem is, I need a new one.
What a muppet I am.
mudinureye
And, thank you, miked!!
x 94
Unread post by citronut »
i see you have this posted in for sales and wanteds on this site to regards malcolm
jeremy
Unread post by jeremy »
Many sensors in fact are repairable as the lead fails. Examine the lead for any damage which may give a clue where the break is, cut the lead and see if you have a circuit between the centre core and the screen. On mine for some reason the outer insulation had become porous and allowed the screen to corrode. I found sound cable and soldered in co-ax cable with a flexible core.
Incidentally you probably won't be able to get the rear ones out without damaging them. I repaired both of mine in situ and one is still working more than 5 years later.
jeremy
mudinureye
Thanks all. I am going to spend the weekend working on the car, see if I can put it back on the road. I am planning a trip to France in September and would rather take the Bx with me than the other car. I thought I might get it serviced while there. Anybody had any experience of this? Surely the French would be more au fait?
