what alloys can i fit to a 1993 xantia i.e 309gti's etc
G J Wright
alloys for a xantia
dirtydog
Hi
Just been into this myself last month.
I found that all peugeot 4 stud, all ford 4 stud will fit but you will have to enlarge the centre part on some ford alloys so that it will fit over the xantias hub, I got myself some nice citroen saxo alloys, also you must try and get the proper bolts.
Regards
DD
Forgot to mention you can go up to 17" alloys.
Edited by - dirtydog on 05 Oct 2002 17:33:27
Regards
DD
Thregwort
dirtydog has this sort of right...
Most Pugs have the same fitting as Xantia, being
4x108, with an offset of 15...22 and a centre bore of 65mm.
However, whilst many common Fords have a 4x108 bolt pattern,
the offset is very different - anywhere from 35-42,
and the centre bore is somewhat smaller at 63.3mm.
Not a straightforward match at all.
"Try to get the proper bolts..." - the Cits steel wheel bolts have a 60 degree fitting face and are not suitable for alloys which require a flat face seat. In addition, the standard 25mm length thread will be insufficient for the alloys which typically (eg for Cit OE alloys)need a longer bolt of 35mm - this dimension is shared with Pugs.
Those thinking of fitting alloys to Cits will find this link helpful and informative.
http://www.tyresave.co.uk/fitment.html
Those looking for the correct replacement bolts should go here:
http://www.trackstore.co.uk/wheelfix.html
and look for the sb29 Pug bolt
