lambda sensor test
Linchpin
lambda sensor test
Unread post by Linchpin »
Hi all, still getting bad idle / flat spots on my XSi.
Anyone know how to test the lambda sensor ?
I was thinking of unplugging it, and seeing if it made any difference to the way the car runs. Is this a good idea?
Cheers
Kev
citroenzx
Unread post by citroenzx »
Linchpin
Not sure. Im not all that clued up to be honest. I know the car passed the emissions test on its MOT 4 months ago. I was thinking of unplugging the Lambda and seeing how it runs. Is this advisable?
PowerLee
Unread post by PowerLee »
Hi
Unplugging the lambda sensor & running the car is NOT a good idea,The car will throw up a fault code in the engines ECU & will also stick the car in limp home mode. You will also burn a lot more fuel & ruin the cat.
Also if you end up having to get a new lambda sensor, Go for a Bosch one everytime, The cheap universal ones only last a couple of months & you are back to square one again.
Linchpin
Great... Any other way I can test it? The symptoms on the bottom of that site all are what im getting, except the emissions bit.
PowerLee
Hi
You could either seek a fuel injection specialist to test your car or stick a known good sensor in & see if the car performance improves over a week or two.
Or buy a new sensor, About £100 from Peugeot but cheaper elsewhere for the same one.
Any ideas what make of sensor is fitted? What car is it on? What engine?
Linchpin
Hey powerlee, thanks for the help.
Not sure of the sensor make, but its a pug 306 XSi, P reg, 100k on the clock.
Kev
PowerLee
Hi
This 306 XSI, Not that it matters much but is it the 8 or 16 valve engine?
If 99% sure its going to be a Bosch lambda sensor fitted to the car.
If you have a look at the body on your sensor, It should have BOSCH & then a 10 digit number on the metal body,The number will be something like X XXX XXX XXX, Get this 10 digit number off the sensor & quote this to any Bosch automotive dealer & then they can match up the exact same part from this number but CHEAPER then Peugeot.
When working with Bosch, ALWAYS quote the 10 digit number for an exact match up.
Linchpin
16V lump in this one.
Kev
Linchpin
Ok, quick update.
I spoke to a company, that said my Coil pack cold have spiked my ECU? I had the ECU code read, and was nothing on there (no fault codes).
I may have an oppertunity to get hold of a working GTI6 throttle body, any idea if this will fit? or can i transplant the sensors into my throttle body housing.
Sorry if i dont make sence, i dont really know what im doing lol im going to pass this onto a mechanic friend
PS.
will trade PC technical work for car fix! :-)
Cheers in advance!
Kev
M11REH
Unread post by M11REH »
[:D]Hi if you are looking for a Lambda sensor try www.pugbitz.com these guys are fantastic. Give them a ring and 99.9% of the time they have the bit you want.
They strip and break only Peugeots so know their stuff. I had similar problems to you so bought a 2nd hand Lambda sensor.
Cost £17 inc postage! A genuine Bosch part off the same type of car as mine + they come with a warranty.
Sorted my car anyway.
Give them a call!!
Linchpin
Did your car also idle too high, then drop down once the wheels had stopped?
Cheers
Kev
PowerLee
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Linchpin</i>
Cheers
Kev
Do you mean the idle speed is higher then normal when the car is still moving slowly?
Linchpin
Sometimes high, sometimes low, sometimes huting, rarley OK.
Its kinda random.
