Hi all,
Looking for help with this problem: engine (V6) starts fine from cold then as it warms up (when stationary) it starts to miss fire, then wont accelerate at all, then coughs and dies. It will not start again until cold i.e next day[?][?] [:(]
XMV6 cutting out when warm
AndersDK
Mosser
Paulxmski
AndersDK
I have no idea on the V6 engine - but I'd think on the clutch bellhousing somewhere to read off from the flywheel. It would be a magnetic coil sensor and probably have an ohmic resistance in the 100 ohm region.
A trip in the oven and the ohmic resistance will likely show a disrupted (high resistance) sensor.
Paulxmski
Mosser
Paulxmski
XM-V6
Hi Paulxmski
Maybe you can take a close look to the fuel pump relay,his connector and the contact pins.
I had similar symptons on my pug 206 1.1, It turned out to be one pin of the relay being bend and blue after being heated.
After some cleaning and rectifiing that pin it worked well again
for past year.
Greetings from Belgium.
for past year.
Paulxmski
XM-V6
Hi
look at: http://www.facet.it/index.asp select english language by clicking ("lingua")
When i look they are all the same
Succes
Succes
Paulxmski
Hi XM-V6,
As you may have seen from my new posting your advice on cleaning the relays was my first task today and it paid off because there is no more stalling when warm, however it does stall when the A/C cuts in. Big vote of thanks to you. I think it's the relay, but although I cleaned it and applied a small amount of copperease grease it hasn't improved. I have noticed that the revs are low around 850 and don't pick up to compensate for the A/C load. So it stalls not sure what can be done about this as the ecu fixes the revs and apparently adjustment is not possible[?]
