I'm about to embark on a timing belt change (ZX-Diesel) and I suspect that the adjuster may need a look at. Having gained inspiration from the forum before I recently tackled the heater matrix (what a swine of a job) I thought I'd ask for advice. Any appreciated.
S M Kelly
ZX Timing Belt & Adjuster
alan s
- RIP 2010
- x 6
Suggest you have a look at the "common problems & solutions" on this forum & look at an article on cambelt change on a BX. There is a link to a web page which shows a photographic detailed description of what was done & how to do it & is pretty self explanatory. I would imagine a ZX would be fairly similar. It is worth noting, that it is recommended that the water pump is replaced at the same time as the timing belt.
Alan S
Alan S
