BX TZD Rev Counter Sensor - FIXED
G4EIY
Unread post by G4EIY »
Hi Folks,
Having problems with an intermittent reading on the rev counter.
Checked and cleaned external plug connections, no change.
Questions:
1.Does any one know what the resistance should be on a working sensor?.
2.Has any one used a RPM sensor on diesels, not fitted with a RPM gauge?.
SORTED...
I can confirm that the sensor fitted to BX diesels not fitted with a RPM gauge works..
The resistance was about 60 ohms...
Cheers
DLM
Unread post by DLM »
I came across an unusual combination a while back - an 88/89-ish BX 19RD estate that had been given a replacement engine a couple of years later. Despite the fact that there was no rev counter in the car, it had a tacho sensor fitted, as it was standard by that time on just about all UK models.
x 94
Unread post by citronut »
the sensor not hooked up on diesel bxs is test point regards malcolm
x 1238
Unread post by Peter.N. »
They don't just go open circuit, the rev counter on my XM would rise to about 1000 rpm then drop back to zero, when I eventually managed to remove it, it had been damaged by something that the flywheel must have picked up and the winding was falling off. Flywheel bottom cover plate missing!
Peter. (G0HET)
tomsheppard
Unread post by tomsheppard »
220 t0 270 Ohms.
G4EIY
Hi Tom,
Interesting!!!...
Well the 2 that I have here are both off of 17 diesels, one from a BX, and the other from My Visa.
They read 69.3 and 63.4Ohms respectively.
The one from the BX works, and I see no reason why the other one would not work either.
The original was open circuit in the coil, so could not verify the resistance.
Cheers
Brian
