306 dash lights
moomin
306 dash lights
Unread post by moomin »
does anybody know what sort of bulbs a 1994 306 will take for the instrument pannel, (is there a model number of them or anything), just didnt want to have to take one out and drive to the shop with no dash. also, how easy are they to do?
bruwerhj
Unread post by bruwerhj »
I cant remember what type it is but i can tell you that you can remove speedo cluster in under 15 minutes
pmb43cam
Unread post by pmb43cam »
Hi. i can't remember what bulb it takes but i do know you can get them from halfords for about 70p. All the bulbs are the same, so it doesn't matter which is gone. You can either buy them with the black plastic surround or just the bulb. Assuming you are replacing a blown bulb, just go for the bulb on its own
Hope that helps
phill
x 1490
They're usually a 1.2W 'capless' type. Do yourself a favour buy about 20 bulbs and change the lot - you don't want to have to take the cluster out again in a few weeks to change the rest of them!
