<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kowalski</i>
White smoke at starting can be a few things. It could be a glowplug or two off, it the car is rough for a couple (10) seconds or so and gentle accelaration makes it smooth and stops the smoke, thats fairly typical of a glowplug off. It could mean you have an air leak on the fuel system somewhere (injector leak off pipes are the usual suspect), if before you try starting the car after it has stood, you pump the fuel bulb and it starts smoke free, then thats fairly diagnostic of an air leak. Oil leaking past your turbo seals or valve seals on the exhaust side can cause white smoke, although I'd expect the car to use oil if this were the case. Alternatively, and this is the possibility you don't really want, the head gasket can leak and your coolant can get into the engine and come out of the exhaust as steam. If that were the case your coolant level would be falling. Is that enough for you to think about?
Hold the car on the handbrake not the footbrake and the sinking at traffic lights thing just isn't a problem at all.
Cheers mate, Its deffo oil smoke as its heavy and grey, its just like the car is clearing itself out for a few secs, takes a few turns of the key to get her started from cold, seems fine once warmed up. The engine was rebuilt 2 years ago (a month after we bought it) due to head gasket failure, diesel leaks, oil leak and a few other probs, so im confident it isnt the head gasket.
Gonns check starting after the fuel primmer thing and if that does not fix it ill just get some more glow plugs.
Thanks for the help
