What is likely to be damaged when an engine has been exposed to freezing cooling water ?
The engine in question is a '92 BX16TZI (type BDY or BDZ).
I stock a BX16TRS engine (type 171C).
As far as I see it the block would be a direct swap as both types have the same bore & stroke. Of course only if the TZI cylinder head has survived the frost damage.
BX 16 engine frost damage.
Dave Bamber
oilyspanner
Mosser
I repaired my boats 2.1 diesel engine after water froze in the engine and it sustained a long crack along the block on the outside wall, so all i did was clean it up and slap some chemical metal on the outside of the block and it worked perfectly with no leaks for over 4 years and was still going strong when i sold it
AndersDK
