I'm trying to replace the catalytic converter on my Xantia Hdi Exclusive after the previous one rusted through. Got the back bit of it off fine, the front section is defeating me.
There are 2 spring loaded bolts that hold the front bit on, that you have to get a spanner on the back of them otherwise they spin continuously. Got the NS one off, the other one I can't get access to get a spanner on it. I'm tempted to try and cut the bolt off, but will I get the new screw in and how would I tighen it?
I'm wondering if I need to remove the heat shield to improve access but I can't seem to remove that either.
Anyone done this before, any hints suggestions?
Cheers
Richard
Xantia Hdi Catalytic Converter Fitting Help
Richard Gallagher
There are two ways of tacking this, either from underneath with long extensions using a socket set or from above with a ratchet ring spanner on the nut. To hold the bolt in place, use a offset ring spanner on the bolt head. When working underneath, an assistant can be very useful to hold the ring spanner in place.
- x 1240
- x 94
bernie
- x 94
rdj104
Well I have now got it off, I ground the nut off in the end as the other end of the bolt was rusted and rounded off. I tried to fit the new one just now, but the new sealing ring I've been given is the wrong size, so will have to wait till Tuesday to sort that out.
I hadn't thought about replacing the cat with a pipe till reading this forum, and at £114 inc vat for a new cat and fitting kit I wasn't too upset.
Kowalski
I decatted my Xantia and the engine is more torquey low down now as well as the fuel economy being better.
The bolts that hold the exhaust on have a tapered thread, which acts as a locking device. On the older Xantia I could get at the tops of the bolts from the top, but on the newer one I had to do it all from the bottom, I used a 1/4 socket at the bottom and a combination spanner (one open end, one ring end) at the top.
If you couldn't get in with spanners how did you manage to get in with a grinder?
rdj104
I was able to get access to the bottom nut with a dremel, it was the top end of bolt I had very limited access to. It was a very slow process, but once started you're committed. The good thing is that as long as you've got sparks coming off you know you're making progress.
I was able to get nice 1/2" 10mm socket on the bottom with extension bars, couldn't get enough pressure on the top end with spanner to hold it.
bernie
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Kowalski</i>
What model front pipe did you use?
Kowalski
