C5 headlight cables-who's who?
406 V6
Unread post by 406 V6 »
Hi fellas.
I thinking in fitting some auxiliary driving headlights on the C5, either connected to the high beam or to the fog lights, with the later one permiting more flexibility, as the fog lights point 2 metres ahead of the vehicle and don't hurt the incoming driver's eyes.
They would be most usefull in highway and for expanding the high beams on general driving.
So, here's the topic question: which colour is for high beam and which is for fog lights, as they are in the same cluster(i don't have Xenon as standard...).
By the way, has anyone have had experience with Hella's FF300?
Take care all
x 94
Unread post by citronut »
the best way to find out is to check which terminal is live without fog lamps on then again with them on, you should be able to work out from this wich is which,after saying all this i think moden car lamps put out fare to much light,even on dip beam they burn back of your eye balls and melt your rear view mirror regards malcolm
