rear brakes xsara
moggy
rear brakes xsara
when i have some weight in my boot of my citroen xsara feels like rear brakes or hand brake keep applying when going over small bumps back end keeps dipping down any ideas what can be causing this?xsara is fine without any weight in boot
- x 94
jeremy
If you are not touching the brakes aned no-one has fiddled with the master cylinder installation then I would have thought the problem must have something to do with the handbrake, and I'd look at the cables first, especially if they have been adjusted tight and then siezed.
The reason I mention the master cylinder is that if the piston return is restricted the pressure in the cylinder will not be relieved by uncovering the recuperator ports.
jeremy
jeremy
- x 94
