hi,
xantia 1.6, '93.
i checked my central locking relay yesterday (the one under the central console), had to remove the console including disconnecting of the rear window switches, now the drivers side rear window will not move<img src=icon_smile_sad.gif border=0 align=middle>.
i've checked the switch itself, that's ok. checked the fuse's (F10, F30) ok as well, even the switch on the door itself won't move the window.
it worked ok before removal of the central console.
could it be the relay in the door?, or is there another fuse that i've missed, or something else.
dom
drivers rear window
Dave Burns
If it were me and the nearside window still operates ok, I'd go look at where I'd been messing about, i.e the console switch/wiring area.
There's no relay in the door just the motor and the switch, there is a relay to dissable the rear function via the dash switch, but you can just about forget that because the other window works.
Dave
Dave
shaunthesheep
shaunthesheep
Its getting power as the switch lights up checked last night.
checked the connections today.
got power on pins 2-4, value 0.5, NO POWER/CONTACT on pins 1-5, so it looks like a problem with power getting from the switch to the motor <img src=icon_smile_sad.gif border=0 align=middle>.
dom
dom
shaunthesheep
jeremy
Try hitting the motor and see if it comes to life again! Worked on my BX for front passenger window while on holiday and functions perfectly if not dropped fully.
May be brushes sticking or overload contacts not resetting properly - one day when I've got nothing better to do I'll take it apart but in the meantime I'm training my wife not to lower it all the way!
jeremy
jeremy
shaunthesheep
jeremy
shaunthesheep
