update: Mysterious air leaks; solved!
freek
Unread post by freek »
Last week I wrote about the air in the fuel system of my bx trd turbo. I thougt I had found the cause and suspected corrosion of the filter housing. But a day later the car didn't start again. I already planned to have a look at the fuel hoses at the tank today, when I decided to have a more detailed look at the hand pump. Although I renewed all the rubbers app 2 years ago, an air leak somewhere near the filter was still the most likely. So I dismantled the hand pump, and to my surprise the membrane was stiff instead of flexible. This could never have sealed the housing in this condition. In less than 2 years! After replacing it the motor started instantly and runs now really without any trace of air. Good example of bad quality of spare parts? Or just bad luck..
Regards, Freek
x 94
Unread post by citronut »
you must have differant primer in tulip land,as in UK this is a sealed unit not intended to be repaired,like mostly everything these days chuck away society regards malcolm
freek
In Holland, and I presume in every country, you can buy a repair kit for the Bosch/purflux filter. It contains the valves, the spring of the pump, the membrane and some rubber seals. You can reach the membrane by bending the 3 clips of the cover and removing the cover. I used 'Diesel parts, art. 14.998'.
