Hi folks,
I have just taken delivery of a 2nd hand 6 CD multichanger for my car and I'm hoping to fit it at the weekend. It's a Clarion CDC634 with the round DIN plug lead. My head unit has the CD button on it which just says 'connect' every time I press it. Hopefully the changer lead will be the right one. If not, do I need some kind of cable adapter?
Now, I've looked under my drivers seat and behind the panel on the passenger side of the boot and cannot find a cable. Is it possibly on the drivers side instead? Failing that, if it's under the drivers seat, are they normally really well hidden?
I'm hoping the thing will just fit and that I don't have to pull the interior of the car to bits to do it. I'm tempted to put it under the seat, but I'm not sure how to pull the central console to bits to get the cable under it. Would the boot be a better option?
Cheers,
Chris.
CD multichanger
citroenzx
citroenzx
http://www.incardiscount.co.uk/acatalog/CITROEN.html is the bottom one any help?
Johnno
For what it's worth, I fitted a Blaupunkt CD changer to my 97 Xantia. The unit was bought on Ebay and had the round connector. I contacted B/punkt and got the adaptor number then purchased it on-line from BlueSpot Car audio. I couldn't find any factory-installed cabling so I fitted the unit under the passenger's seat, feeding the cable from behind the head unit until it was visible through the keypad space (your's will have a 'change' holder - I'm assuming it will just pull out). I then fed the cable along the central console, undid the bolts under the ashtray on the rear, and lifted the console enough to feed the cable to the unit under the seat. The unit isn't bolted down and has been happily delivering music for some months now.
I think that Clarion units were fairly common. There are several threads on this forum on this very subject.
Hope this helps.
Hope this helps.
Chrispy
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by citroenzx</i>
Aha....that looks like the one. Mines a slightly older model but looks the same. The head unit is a 4035 I believe judging by the handbook. I hope the back of it it the round 13 pin DIN one.
Chrispy
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Johnno</i>
Hope this helps.
Ahh I see. Excellent! I shall give that a go. With the ride hight adjuster being on there I didn't wanna start just pulling it all apart. Firstly though I shall pull out the head unit and see what connector it takes. Hopefully it'll be the round 13 pin one and it'll just fit. If not, I'm hoping I can get an adaptor for it.
Am I right in thinking earlier cars had Blaupunkt ones and later cars (MKII's) had Clarions?
Hope this helps.
Johnno
dnsey
- x 19
If you prefer to mount the changer in the boot, it's not difficult to run the cable from the head unit under the soundproofing above the passenger footwell and along the side of the car. Unclip the door seals, and it will fit nicely alongside the carpet edges. The seal will retain and protect it when refitted.
tanto
Chrispy
Chrispy
Well, got it working last night. I had to pull the changer apart to get the magazine out. The slots for the CD's had popped out into the changer thus stopping it from ejecting. I popped them back in and then it ejected fine. Sounds pretty damn good too! I've decided to fit the unit in the boot and do it properly. Means I've got to pull the passenger side carpet up and take the trims off the door opening at the bottom. I hate taking interiors to bits! It always goes wrong.....
silverback
dnsey
- x 19
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Means I've got to pull the passenger side carpet up and take the trims off the door opening at the bottom. I hate taking interiors to bits! It always goes wrong.....<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Don't worry - it really is very easy on a Xantia. with care, the cable can be eased under the trim between the doors and beside the rear seat without removing it, so there's nothing much to go wrong[:)]
Chrispy
dnsey
- x 19
[quoteSo you don;t have to pull the door seal off at the bottom][/quote]
Yes, the seal has to come off, but it goes back easily and just as it came out. There are no screws etc. to relocate - it really is easy! It's the bits in between where the cable can be eased behind rather than removing the trim.
