2.1td belt broken - engine dead
Thunderbird
On a XM mk2 2.1td automatic, one of the belts blown, I believe it was the secondary belt we can see from above. Engine went dead. Strange noises point to severe damage inside the engine.
What is the typical consequences of a broken belt on this engine? Can one expect the main block and pistons to be ok?
ActivaV6uk
Thunderbird
ActivaV6uk
Lift the head and if it looks really bad replace the engine, I hate to say it I would think its terminal as I’ve seen 2 of these with belts gone now and one ware it just jumped 2 teeth all 3 engines had broken con-rods, pistons and very bent valves one even had bits in the turbo from the engine!
If you want to know that its teminal very quickly unbolt the sump if its full of metal and chunks of piston replace the enigne
Andy
Andy
- x 1240
Thunderbird
ActivaV6uk
BX-Basis
ActivaV6uk
ActivaV6uk
Thunderbird
ActivaV6uk
Thunderbird
ActivaV6uk
CommY
