Rear door / Interior light
user_3150
- New User
Morning everyone, I have asked this question before and at the time was told if you can live with it leave it alone. At the time I could but now since moving house the door is being used all the time. Right the problem is that the rear O/S door doesn't activate the interior light's. I can't see anything that trigger's them so I am assuming it's linked to the lock mechanism. Has anyone tackled this problem or am I going to be the first. I would just like some advice as I hate removing door card's as the clips break and the never go back on as well as they came off e.t.c.
jeremy
Every interior light I've seen is simply operated by a push switch in the door hinge face. Citroen ones are black plastic and are fixed with a single screw and sometimes have a rubber gasket and cost about £1.50 from GSF.
Find the switch, unscrew it and take it out. there should be a single wire on the back. Earth this wire to the bodywork and the light should come on. The switches usually last about 8 or 10 years, you may be able to clean your oldone or alternatively its earth may need a clean.
jeremy
jeremy
Homer
- x 16
jeremy
dieselxantiaman
user_3150
- New User
johnny
user_3150
- New User
NUT'S I missed your reply Johnny and just spent the last 2 hours removing the door card and getting the lock out only to find it can't be stripped (not without it falling apart anyway). I will check the wire's and if I find no problem I will get a door lock from a scrappy. I will let you know how I get on. Bet it's the wire's though AAAHHHH!!!
