Replacing ABS sensor - aaaarrgghh!!
- x 94
alan s
- RIP 2010
- x 6
You'd almost have to wonder if there's 2 different types of sensors and one is longer than the other, if the spacer is in fact a bodge job on the wrong sensor?
It's unlikely they'd have to pack the correct sensor unless this is used as clearance adjustment.
From memory, a BX has only about 1mm clearance between the sensor and the serrated wheel. Perhaps someone with the right knowledge can confirm this; Malcolm??
Alan S
Alan S
jeremy
The important bit here is the distance between the toothed disc and the sensor end which should be very small (BX 0.30 to 1mm) If you can get the thing fastened securely with this order of gap then I would expect it to work.
I know you have a Xantia but would have thought that the fitting was the same.
Incidentally having fitted it make sure you evry carefully rotate the wheel/shaft a few times to make sure there is no contact.
Jeremy
Jeremy
alan s
- RIP 2010
- x 6
FWIW,
THis is one off a BX16V.
I've posted it just as a comparison in case that's what you have.
I have seen a Xantia but hot out of the car so can't remember exactly what it looks like but from memory a lot different to this.
Another point to save double work; be sure that the serrated wheel is nice and clean before reassembly. Clean from both rust and grease or grime.
Alan S
Alan S
acrowot
The sensor in the pic that alans has posted is very similar to the one fitted to the later Xantia, I think 94 on. The sleeve that the third finger on the left hand is touching in the pic is about 4mm longer than the sleeve fitted on the earlier sensor ( pre 94 ). If you try to fit this earlier sensor to the later car the sensor head will touch the toothed disc ( you will not be able to fully tighten it ). What I did in similar circumstances was to measure the later sensors length with a mike and the fit washers to the earlier shorter sensor to make up the difference ( I think in my case 4*1mm washers ). This was a temporary solution that I did 18 months ago and I have not had any problems with it so I may just leave as is.
acrowot
ghostrider
My leads are the same, jap manufacturers use some type of grease in these vulnerable connectors, silicone at a guess. At least you can get at the connectors, the ones on the CX are completely buried, but only as far as access goes [:D] [:D] [:D] [:D] [:D]
Pete
________
YAMAHA GTS1000 HISTORY
Pete
________
jeremy
- x 94
Stinkwheel
- x 94
