Today I drove into town and noticed that the engine revs stayed high, as if the choke was on, even tho the engine was now warm. Following this were a few judders. By the time I decided it was time to go home, the engine revs were going up and down, kind of vroom vroom vroom, like there was a small pixie under the bonnet jumping up and down on the accelerator cable.
Hmmm, i thought. I opened the bonnet and twiddled a few cables. Decided to disconnect the cable to the rear of the injector assembly, this made the engine cut out, but also made a little buzzing noise, like it was resetting. I recconected and restarted the engine. Its running ok now, but tickover still seems a tad nifty. Any ideas? A dodgy sensor maybe? Its been fine up till now, with the choke going off within a few minutes. Im quite annoyed now, not due to the engine, but due to the fact that when i closed the bonney, the headlight glass dropped out and smashed on the tarmac, oh joy!
My car is a '93 ax debut.
regards,
Tris.
ax running.
ItDontGo
Mine used to rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die, sorry where was I oh yes, then rev then die then rev then die then rev then die etc...
That turned out to be due to the throttle solenoid. It also made it really jerky downshiftinh.
tris
fastandfurryous
- x 4
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by ItDontGo</i>
rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die then rev then die etc...
I think that's known as "hunting".. or in your case, "serious hunting"!
oilyspanner
tris
- x 94
ItDontGo
My problem was the throttle sticking open a bit and the ECU cutting the fuel or injection as the idle speed was too high.
That sounds odd but it used to take a while to realise it had a problem. Hmmm I'm not explaining it very well am I.
It was supposed to be a self-learning ECU which reset after the battery was disconnected but I remember thinking it only learned how to p*ss me off. By the way kids *=i
tris
the car is being a right bugger as recently the problem has come back and seems to be permanent. The choke comes on as normal when cold then onced warmed the engine revs up and down continuously making it a bit difficult to drive! Juddering high idle and sometimes there is giant flat spot!
Decided to have a quick look earlier.. on first inspection a little oily, but nothing excessive. Got my handy torx kit out and started to have a play. What is the component on the right hand side? there seems to be some adjustment via rotation. I tried this with the engine running and i can either get no hunting with rough idle, or no hunting with the engine revving its nuts off. So decided to put back to normal. So, engine is still hunting and using more fuel than normal. Tbh I dont wanna drive it till its fixed as driving around with the choke on all day cant be that good for the engine, let alone the catylist. But work is a good 15 miles and I'm on call. Any more ideas guys? Throttle doesnt seem to be sticky, throttle body now very clean with thanks to carb cleaner. Im thinking airflow/temp sensor fault?? Where are they locateed, as there are a few ax's, 106's in the local breakers which I could swap parts with.
Regards Tris. (still the same '93 ax debut)
- x 94
Ian Fearn
