xantia petrol filter
tj
Unread post by tj »
I am trying to replace my fuel filter on my xantia break. The problem is that there is no recognisible clips or any kind that secures the input/output hoses. The original hose ends looks like a moulded plastic end that defied my attempt to detach the hose. I dared not try too hard in case I break the hose. Is there a correct way to do it which I am ignorant of?
http://www.alllinuxcd.com
xantiav6
x 3
Unread post by xantiav6 »
The moulded plastic fittings have release buttons. Just work out which side it is and press the side firmly and it should slip off the filter.
