Wrong spheres fitted
SethY
I have fitted the incorrect spheres to the rear of my Xantia! I have fitted the ‘Hydractive’ spheres and I’ve just found out that mine is the ‘non-Hydracive’. I blame the Hynes manual for confusing me, but actually it’s totally my own fault! The ride is pretty firm (similar to the flat spheres that I was replacing). Will having the wrong spheres on damage the car or can I ride around on them for a while before I fit the correct ones?
406 V6
- x 1240
SethY
Rostami
Thunderbird
SethY
406 V6
Sethy, you shouldn't waste money on HA spheres for the front.
Just get a set for the rear and enjoy the ride of a Citroën.
If you would put a set of HA on the front, you would have the handling of an HA2 Xantia, but one at permanent hard mode.
Get the right ones and try not to get into trouble until then[;)]
