dear all,
I have recently bought a zx 16v 2.0 k reg (xu10?) for a friend for trackdays and am looking at cheap ways to get a bit more oomph from it.
We are going to replace the cat and exhaust for a bodgy straight through design and I was wondering if this will have any ill effects with regards to the o2 sensor reading to the ecu?
I know there is a few derivations of this engine (i beleive we have the 155bhp one) and wondered if an ecu swap will help matters at all? i think this one is 3 plug one - eg the emissions one.
Has anyone experimented with fuel pressures with an air filter?
If you have any ideas that you ever wanted to test, but were too worried to try because you didnt want to wreck your car - nows the time!
Remember this is a track car and any mods should be free or at least very cheap.
Any ideas at all welcome![}:)]
Cheers
Greg
zx 16v power enhancements
citroenzx
VisaGTi16v
macaroni
Not sure about those cheap chips, likely to kill your engine after a few track laps, but the best and cheapest (free!) way to improve performance is to strip the interior.
You will be surprised how much weight can be lost by removing things like back seats, parcel shelf, trim, etc.
I saved 32kg on my 205 with some simple removals and if you then recalculate your power to weight ratio, you will see how much extra bhp you would have to find to match it and that would be more expensive.
Like you said, filter and cat removal is a good way to liberate about 5 bhp and make a good noise too. Cat replacement pipes should be available for your car and are quite cheap, they should also have a hole for the lambda sensor, if it requires it.
Also, make sure the engine is working as well as it should, ie make sure the plugs, leads, fuel filters and oil are renewed. Fairly obvious stuff, but can make a difference.
Hope this helps.
Hope this helps.
VisaGTi16v
Yer re:engine make sure the 2 ACAV valves move when you rev it as they always break on that engine. Got a photo somewhere... http://homepages.nildram.co.uk/~visa/pi ... engine.jpg rev it and watch, they should both pull in
oscarloco
mrbump
hi,
already done the obvious stuff like interior and service. have positive pressure induction as well.
both acav valves are working, but am probably going to lock them in the short intake path position.
has anybody used a cat replacement before? any other fiddling required to get the correct reading from the o2 sensor?
cheers
cheers
Chrispy
Removing the cat will have 2 possible effects. The extra back pressure of having them on provides additional torque low in the rpm range. Removing it reduces this effect but will help engine breathing at higher rpm. On the track, high rpm is what it's all about. On the road, it's torque.
Get a proper ECU remap/ chip. DO NOT fit one of the resistors you see on eBay for 10p. They fool the ECU into shoving loads of fuel into the engine and cause bore wash. In warm weather your car will simply go bang. Also, if you have a lambda sensor then chances are this wont work as the sensor will correct the rich mixture.
Next thing is a decent induction kit with a cold air intake from behind a headlight or something. Hotter cams are a good idea but are costly and may give you a lumpy idle depending on how hot you go. After that my friend it's a turbo and a reduction in the compresiion ratio. Getting more BHP is never easy unless the engine is blown and even then it can be risky.
Chrispy
Oh, and as for the de-cat, make sure you get one with a screw hole for the O2 sensor. Removing it messes things up something rotten. A rich/ lean mixture means the engine is running less than optimally and possibly not outputting the HP it could. I've seen de-cats without this and all they do is backfire and pop and smell. Not good.
