Can anyone tell me how to remove the standard stereo/radio from the Citroen ZX. The one with the plastic flap.
Please help this is driving me insane
Citroen ZX - removing the stereo. HOW?!?
Dave1
- x 3
volcane305
Its a very simple job. Firstly look for the code for your radio it will be handy to know if you have it before removal. Lift up the flap thing and you will see two rubber bungs, one on each side pull these out and remove the screws, I think they are a strange type possibly torx so a good screw driver set is needed. The radio will then pull out. There are four more screws holding the mounting plate in place. You will need an adaptor plate to install a new stereo (same part as for berlingo) these tend to be overpriced about £20. The stereo has ISO connections which means easy connection.
n/a
hallucyn8
gjb02
Alan White
